Referral
Public_guy
My brother switched to Public Mobile a while back and was signing up at Walmart.. he had my referral code ready to use but forgot about it till after the fact and they never asked for one.. is there a way to use it after signing up? Would be nice to know for the future if this happens again.
9 REPLIES 9
OlivierR
https://widget.telus.tiia.ai/publicmobile/publicmobile.html?lang=fr You go to the link then write "create ticket" then you click on "contact us", after that you choose what is your problem in the option it give you and then if you are not logged in your account it will ask you to logging to create a ticket
fixin
@Public_guy - There is a similar thread from 1 year ago saying that Public Mobile is self-serve only & no more Walmart & London Drugs activations
https://productioncommunity.publicmobile.ca/t5/Announcements/Your-Public-Mobile-experience-just-got-...
Public_guy
Thank you!
Public_guy
Yeah it's been quite a while, I won't be attempting to get that referral from my bother but it's nice to know that it would be possible to in the future had the same situation happened again, thanks.. how do you open a ticket?
OlivierR
Customer support can apply the referral afterward if you forgot but since its been a while I dont know if they will, you can always try to ask them You can create a ticket by asking the chat bot "create ticket" and answering the following questions here's the link https://widget.telus.tiia.ai/publicmobile/publicmobile.html?lang=fr
@Public_guy
Retailers like Walmart and London Drugs stopped activating SIM for new members over a year ago.
Also, you can’t referral code on your own account.
@Public_guy
if your brother sign up in Walmart, that was looooooooong time ago.  PM has gone all online for activation for over a year
Since it was that long, support would not be able to apply the code back.  Sorry
Chalupa_Batman
Hey @Public_guy
It depends how long back it was. Usually they have a 1-2 weeks window. If it's been more than a month, I don't think it will work.
You can create a ticket using the chatbot below right corner. But once again, if it's been more than a month, I wouldn't even bother creating a ticket as the answer will be no. I'm positive on it.
