08-18-2022 11:05 AM
Hi everyone,
I used a friend’s referral code to sign up and didn’t receive my one time $10 credit that was advertised. Anyone know why that might be and/or how to claim it?
Joining Public
Rewards
08-18-2022 11:21 AM
It takes 3 days to show up. Just in case, check with your friend if he sees last 4 digits of your phone on his account to confirm you entered referral code correctly.
08-18-2022 11:17 AM
HI @Proud2bcdn If could take up to 72 hours for them to deposit the money into your My Account. You will see it as Available fund there
If it has been over 72 hours, please open ticket with CS agent:
To open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Start by Typing: My rewards are missing,
Select "Public Points"
click on "Refer A friend",
then click on "Yes, I'm the referred customer',
finally click "Click here to submit a ticket" .
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
08-18-2022 11:17 AM
@Proud2bcdn hi it takes up to 72 hours to show up in your rewards if it has been longer
you need a customer service agent to inquire why
you will need to open a ticket, to speak to a customer service agent Click here check your community envelope top right corner next to your avatar for a reply ,or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
08-18-2022 11:15 AM - edited 08-18-2022 11:17 AM
It will take 72 hours for the credit to show up in your account.
If it takes longer, I would suggest you contact a CS_Agent to have it adjusted.
08-18-2022 11:14 AM
@Proud2bcdn , it can take up to 72 hours for the $10 to show up in the account.
