Referral code not showing
Acp3465
Hello
I just registered and the referral code is not showing for my friend. How do I fix this so he gets credit
Thanks
JL9
Is your friend on the old rewards or the new rewards (points)? He won't see anything on his account if it's the latter. He will just get a cha Ching text about the referral and then will see 1 point every month you are active
hairbag1
..."just registered"...give it 24 hours for the credit to be applied. Keep watching and let us know when it appears. If not withing a few days...contact CSA for their assistance.
RossN
@Acp3465 he should see his 1 dollar soon the sight seems a little sluggish today your10 dollar credit will show within 72 hours unless you mean you  referered him then just the opposite 😀
Timer
@Acp3465
contact to support team by CS_Agent  to add it.
