Referral chart ??
Grinch
The top part is an “estimate” of 12??
The bottom part appears to be correct.
So if I received a new referral would the bottom part change from 9 to 10? And how quickly?
Thanks.
hi @Grinch
you have to use the app.
While you can start the activation on the browser, it will ask you to go back to app after payment step
So, better to just start from the app
Grinch
Ok thanks, will check.
Secondly. To activate a new account….can you still do from a desktop/tablet/laptop browser or do you “have to use” the PM APP?
ORNGNBLK
@Grinch  If someone is added to your referral list, it usually updates next day. If you scroll down a bit, do you see the part where it says “as of xxx date you have x referrals”?
