10-27-2023 09:06 PM
10-27-2023 10:07 PM
@mojorising wrote:Within 72 hours. If it goes past that, message a CS Agent at the the link below.
Keep checking your Community inbox envelope icon on top right after the ticket is submitted. CS Agent will reply to you there.
The 72 hour time frame is for the new customer to receive the $10 account credit.
10-27-2023 09:51 PM
so long as they activated using your exact referral code, and you were not within a couple days of your renewal, you would see it on your next renewal.
If you did not see it on your renewal, that most likely means they either did not use your referral code or they entered it incorrectly.
If they did not use a referral code, they would need to contact the customer support agents to have it applied.
If they mis-entered the referral code, and it was accepted on the activation, someone else has now benefitted from the referral and it cannot be changed.
10-27-2023 09:48 PM
Semi off topic but humorous... I have Jerry MaGuire SHOW ME THE MONEY clip in audio every time I get one of those Cha-Ching messages. I giggle each time.
10-27-2023 09:42 PM
you might get a Cha-Ching message from PM when $ is applied to your account.
10-27-2023 09:40 PM
Each situation will be different but I recievd mine within 30 minutes. But as someone said it can take up to 72 hours.
10-27-2023 09:40 PM
If someone used your referral code you will receive one point on your renewal date as long as that person you referred is still active.
10-27-2023 09:11 PM - edited 10-27-2023 09:14 PM
