06-06-2026 04:51 PM
Hi , my referral code is not showing. I have tried a ton of browsers. I have tried to copy the link to see if it includes it, but even the link is empty (https://publicmobile.ca/en/qc/plans?referral=)
How can this be fixed? Thank you.
06-06-2026 05:22 PM
TYSM for the link. I've just submitted a ticket. It was very difficult doing this with the chat it as well so it's possible I'm experiencing some glitch.
06-06-2026 05:20 PM
Not sure if I'm not communicating well but I keep saying it is not visible. The code itself is not visible whether I copy the link or not.
06-06-2026 05:14 PM
@dnham1 if you really cannot find it, ask PM to help (and your friend can subscribe first without the code , then ask PM to help to add it back after you got it sorted out)
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
06-06-2026 05:12 PM
@dnham1 wrote:Hi , my referral code is not showing. I have tried a ton of browsers. I have tried to copy the link to see if it includes it, but even the link is empty (https://publicmobile.ca/en/qc/plans?referral=)
Hi @dnham1
There have been site issues in the last 48 hours for some, including myself. Yesterday, my referral code was not showing either along with my account balance. Also, my usage wasn't showing.
Today, everything is showing up normally. I didn't have to clear the cache, go into incognito mode or nothing. It just resolved itself. I did however, reboot my computer this morning after I woke up. Maybe that could have resolved it. Either way, it's back to normal for me.
06-06-2026 05:12 PM
Tried this just now and still shows up blank.
06-06-2026 05:04 PM
Dont use the link. Login My Account, go to Referral page and copy the 6 characters code and give it to your friend. When your friend subscribe, he will enter in the Payment step
06-06-2026 05:04 PM
As Ive said I did this and it shows up blank. It is not visible.
06-06-2026 05:00 PM
Go to My Referrals, scroll down and you will see:
below 'Copy...' is your referral code
06-06-2026 04:56 PM - edited 06-06-2026 04:58 PM
using the mobile app; log in to your account > tap the Account tab at bottom of screen....you'll see your referral code.
added..for your laptop...try shutting it down and start again. Clear cache and use incognito.
