06-06-2026 04:28 PM
06-06-2026 04:49 PM
@BashirAlsabi wrote:Whats that new thing about getting ten gb for free and how do i do it?
If that doesn't work for you and you are denied, contact customer service. Some have reported they have $24 plans or higher and the code didn't work or it the 10GB was removed an hour or so later.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
06-06-2026 04:39 PM
You can get 10GB of FREE monthly bonus data for 2 years, when you are on a plan of $24/mo+. You just need to use Code: PMDATA10. Offer ends, June 26, 2026
To use the code, login My Account and go to Subscription & Add-on page there and add the code to the Promotion box
Or on PM app, go to Payment > Redeem Promo code
