01-02-2024
09:46 PM
01-03-2024
03:04 AM
computergeek541
Hello, I need help with the refer a-friend feature.
I recently referred a friend with my code but I did not see any email confirmation nor my account saying about my referral points.
How long does it take to confirm my referral in my account and theirs?
Thank you.
01-02-2024 09:52 PM - edited 01-02-2024 09:54 PM
You'll see that you got +1.00 point from refer-a-friend after your renewal date. You should've gotten a SMS saying that you got a referral. If your friend subscribed before your renewal date, and you didn't receive the points after a few days, contact support.
⬇️ Click the link for an Agent ⬇️
01-02-2024 09:49 PM
@Sam_Cuevas1 Your friend should see it in-there account with in72 hours of activation . And you should recieve a cha ching text saying so . If it’s been over 3 days have your friend submit ticket with support to ensure it was applied correctly
send a private message To CS_Agents
01-02-2024 09:48 PM
should be fairly quick. Look in the Rewards section of your account to see if new referral is noted.
