10-22-2025
12:49 PM
10-22-2025
03:07 PM
computergeek541
Hello,
I recently joined Public Mobile, and then referred my husband to join, which he has. How can I get my $10 refer-a-friend credit?
Thanks
10-22-2025 02:21 PM
Yes, PM will add it back for you
You will need to submit tickets. you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
10-22-2025 02:17 PM
Thanks for your response.
My husband did not see a place to submit my code when he signed up. Is there some way he can submit my code after signing up?
10-22-2025 12:54 PM
hubby gets the $10 credited to his new account within 72 hrs. You get a point every 30 days that he stays with PM.
