Recovery ESIM
Ericpop
@CS_Agent  hi. I bought. Esim  with public mobile first i install it. But the internet was not working so i delete it. And now  i cant install it again can you help me reste my account please
hi @Boki I do see any particular higher risk for accidently charge
Boki
@hTideGnow wrote:
HI @Ericpop
you need to re-buy it again using the app.   But according to the Help article, PM won't charge it since you already have an eSIM
Correct! According to Help replacing existing eSIM if it fails is free. Good luck if you get 'accidentally' charged...
Ericpop
I cant login to the app  bécause i cant get the txt vérification  because i delete the esim
hairbag1
@Ericpop
now you need a new esim. Use the PM app and get a new one to activate the acct.
@Ericpop  Shoot once you delete eSIM you have to log into the app and re buy eSIM
HI @Ericpop
But to login My Account, make sure you click "Didn't receive code" and " send email" to get the code via email
if you cannot login, just message support agent for help instead:
