06-05-2023 10:44 AM
06-05-2023 11:30 AM
My cs agent had sent a message and has now disappeared, do I start the process over?
06-05-2023 11:18 AM
HI @DJ88
if you put in your sim card correct, then please submit a ticket with cs agent for them to check the activation. I think it is just a sim activation problem
06-05-2023 11:15 AM
I’ve rebooted multiple times in hopes it would eventually correct itself. I didn’t receive a sim card, I got an esim, which is a bit confusing since this is the first time I’ve ever heard of this
06-05-2023 11:10 AM
Definitely try to reboot. Also make sure your sim wasn’t dislodged in the sim tray and wasn’t upside down. The tray is keyed but you’d be surprised how many people will force the sim in or that it gets dislodged when being inserted.
06-05-2023 11:09 AM
Tap your avatar next to the bell on top of page , drop down menu will appear and tap messages
06-05-2023 11:09 AM
@DJ88 wrote:How do I get my private messages? I’ve messaged but not sure if I’ve gotten a reply
use this link
06-05-2023 11:08 AM
06-05-2023 10:56 AM
@DJ88 if it is SOS, it is very likely sim card provisioning , please message support first as adised above
06-05-2023 10:55 AM
I’ve tried but keeps saying error
06-05-2023 10:54 AM
Yes I’ve done both. They said it could take up to 5 hours and I was “given” a temp number but never received it. My phones been stuck in SOS since yesterday
06-05-2023 10:50 AM
@DJ88 If you just joined PM try rebooting the phone first and try rebooting network settings also , if all else fails as support to reset your account in there end
Message support directly
06-05-2023 10:46 AM
try to reboot the phone once
try clicking Reset all networks
but it is likely just a sim card provisioning issue. Easy fix for support, but please open ticket with them via direct message
06-05-2023 10:46 AM
Did you port your old number over to PM or picked a new number?
Did you reboot your phone by powering off then back on?
