04-26-2023 06:42 PM
04-27-2023 01:55 AM
@HALIMACS wrote:You'll only be able to receive calls from ANYWHERE in the world if you are physically in Canada with your Public Mobile device. That is, unless you've purchased a US Roaming add-on and are within the USA.
Yes. Incoming calls from anywhere in the world to anywhere in Canada. Outgoing calls from anywhere in Canada to anywhere in Canada (or to other countries, if you have the necessary long distance add-on minutes).
Always login to Self-Serve and check your account status. If the account status is good but these calls are failing then reboot your phone (especially after new activation, changing a plan, or porting a number). Make sure the phone software settings aren't blocking the country or the caller.
04-26-2023 07:05 PM - edited 04-26-2023 07:06 PM
@pamandshawn4749 wrote:About 4hours
@pamandshawn4749 you are receiving other incoming calls?
I would wait til Day 3 before worry it. After porting, most big Canadian providers would be able to route the call to the new provider without issue. However, small and VoIP providers will take a day or as many as 3 days. Similar thing happen with Long distance calls. So, I am pretty sure the US calls will start coming within 3 days. Just need to wait a bit
04-26-2023 07:04 PM - edited 04-26-2023 07:06 PM
Only 4 hours here... did you reply "YES" to the port authorization text if moving your number here from elsewhere?
If NOT, you'll need to reinitiate the port process. I can send you a number to call if you DID NOT reply YES to the PAT (port authorization text) within the required 90 minute time-frame.
04-26-2023 07:02 PM
About 4hours
04-26-2023 07:02 PM
I am in Canada.
04-26-2023 07:01 PM
Voice comes on stating this number not in service.
04-26-2023 06:59 PM - edited 04-26-2023 07:00 PM
I don't think this was mentioned ... but, are you trying to receive them while IN CANADA?
Or are you currently within the USA?
04-26-2023 06:55 PM
Ensure the caller is doing this:
04-26-2023 06:54 PM
@pamandshawn4749 did you just join PM and ported in your number? how long you have activated the account?
04-26-2023 06:53 PM
@pamandshawn4749 is it more than one caller? Are you able to call them? Other inbound calls in Canada are working?
04-26-2023 06:48 PM
Sorry not to voice mail but voice states this number not in service.
04-26-2023 06:46 PM
@pamandshawn4749 wrote:It goes straight to voice mail.
Ensure the number is not on your blocked list.
04-26-2023 06:45 PM
04-26-2023 06:45 PM
@pamandshawn4749 wrote:Why I cannot receive USA calls on my new Public plan ?
It's not supposed to make a difference for you where someone is calling you from. Are other incoming calls working?
04-26-2023 06:44 PM
You should be able to. Ensure they are not blocked and the caller is using the correct syntax to call you. Is it just one number or all US numbers?
04-26-2023 06:44 PM
@pamandshawn4749 You should. What happens when you receive a call originating from the USA?
