10-10-2025 07:54 PM
Hi,
I recently was notified that I had used 95% of my data. I believe I have 20 Gb and I am not sure I have EVER used a Gb. When I check my usage of data, daily, it seems quite high given I almost always am on Wifi especially at home. I am assuming the daily time of usage relates to a cummulative daily assignment and not when it was actually used. In either case I wondering how I was able to use all my data and some clarification would be appreciated.
Thanks,
Dave
10-11-2025 04:27 PM
Hi @Lotusland2 I have the same question. Namely 100 Mb of data shortly after 12:00 AM. Is this simply the daily usage being shown at this time? Also the usage, namely the amount, given I predominately use Wifi, seems a little odd.
Insights are welcome.
10-11-2025 01:03 AM
I just received the same message, and when I checked my data useage, there were a number of high data uses during the middle of the night, when I would not be using it. Can anyone explain this.
10-10-2025 09:37 PM - edited 10-10-2025 09:38 PM
HI @AVTIE
this has nothing to do with your issue
the text was sent out wrong and the usage on My Account was correct. So, the text people got was a system gltich, those users not really used up 95% of the data.
As explained on your post, the usage on your account was correct according to what you showed us.
10-10-2025 09:34 PM
10-10-2025 07:58 PM
hi @Wavo2791
if you checked your My Account and your usage is normal, ignore it, just another system glitch
10-10-2025 07:58 PM
Many receive this text but it is a system mistake, no need to worry
