11-14-2024
06:26 PM
11-14-2024
07:46 PM
computergeek541
I would like to have my receipts from April 2023 until present. I can only access my receipts since November 2023.
They say I should contact an agent if I would like to go back further. I am always either sent to this community posts or an AI who is not able to assist.
11-14-2024 06:40 PM
hi @Melodysalib
yes , they Account login has problem tonight so you cannot use Chatbot
Since you now messaged them, you now need to check community inbox for response from support. You can check the message here
11-14-2024 06:32 PM
I just sent them a direct message using the link you provided. Thanks.
11-14-2024 06:30 PM
I cannot open a ticket. I receive a message that says unauthorized.
11-14-2024 06:30 PM
hi @Melodysalib
you will need support to prepare that for you
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
11-14-2024 06:28 PM
Open a ticket through chatbot. Type 'ticket' and follow prompts until you get a link to open a ticket.
