Reactivate
aminkhoram
My account is suspended. I need to just reactivate it to receive an important message. Am I supposed to buy a plan?
And What is the cheapest plan to buy in this situation? just to reactive my account for a short time
7 REPLIES 7
Chriswilliston0
In my experience 90 days is the amount of time you have to pay your bill without having issues of it being suspended but new plans the 40 dollar 15 GB data is the best by far!!!
@aminkhoram
How long was your account suspended?
It sounds like you un-suspend when you need it but if you let it run longer than 90 days…your account will be closed, SIM rendered useless and you lost your number.
Can you please let us know how long was the last time you paid for service?
@aminkhoram you can't reactivate for less than 30 days as all plans are 30 days.
So, either obtain a voucher or log into self serve to make a payment.
First change your plan to the $15 one, then resume services.
hairbag1
@aminkhoram
you can re-activate your old plan using your credit card by dialing 611. You'll need your PM pin number.
Alternative is get payment vouchers at Shell Gas, dial 611 to add them and reactvate.
The $15 plan / 30 day is the cheapest PM offers.
HI @aminkhoram   is your plan just suspended? As long as suspended the less than 90 days, you can reactivate via My Account login or dial *611 and resume service (with *611, you need your 4 digits PIN)
@aminkhoram   just login to My Account.  You can change plan to $15 if you like
Or generally, if you want to reactivate the same plan, just click on Reactivate my plan and follow the steps :
@aminkhoram  $15 plan cheapest plan if you know Pin number to account you can 611 or with voucher no pin needed  otherwise log in and change plan and reactivate
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
