e mail
02-01-2023
06:06 PM
02-01-2023
06:13 PM
computergeek541
02-01-2023 06:12 PM
Try to login with all the possible emails you have then click Forget Password.
If that doesn’t work then you need to contact a CS_Agent to help you access your account once your credentials are validated.
02-01-2023 06:09 PM
It should be in your paper you signed up with when they print (In pei where I'm from) it was in a paper where it shows your email and everything else like your discount code and everything
02-01-2023 06:09 PM
Look in all your emails for the welcome email from here when you signed up or other marketing and promotion emails from here (not community).
Try all the ones you can think of in the reset password page and maybe one comes in somewhere..
02-01-2023 06:08 PM
@lloydhillier you can try to find if you receive any Welcome email from PM when you first joined, check all your different email
Or you can find by Reset Password. First try to use the Reset Password link on the login page, enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-01-2023 06:07 PM - edited 02-01-2023 06:09 PM
submit a ticket with SIMon Chatboth
typ: forgetting information
and Click, Forgot My account Email
then Click, Contact Us
and, Click here to submit a ticket.
02-01-2023 06:07 PM
Ask agent to hep you out.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private message might take longer.
