Reactivate account
MW11
I have enough money in the account and tried to reactivate it. The account will not reactivate though.
2 REPLIES 2
@MW11  - so, my main question is....do you have all your services working?
If yes, this could be your account going through the normal renewal process. The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew.
So, if this is the case, ignore these messages on your SELF SERVE account.
If you have no services, and it is past your renewal, maybe your autopay failed?
  1. Add Funds to your Plan Amount through SELF SERVE (or by calling 611 if you have a card registered)
  2. Go to “Plan and Add-Ons” TAB
  3. Select "Lost/Stolen Phone" TAB
  4. Select "Suspend Service" BUTTON
  5. Then, Select Resume/Reactivate Service
  6. Reboot your phone.
If this was an Autopay failure, I would let the Customer Support Agents (CSA) know.
Methods to contact the Customer Support Agents (CSA): https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
@MW11 Login to My Account, do you see Available Fund = your plan amount?
If so, go to Payment Tab, one time payment and use the option "Other (Enter the desired payment amount)" and enter $1.  Top up an extra one dollar and try to trigger the process
(if available fund only $0, then you don't have enough fund, do the same thing above but enter your plan amount)
 https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
Once payment ($1 extra or plan amount) is processed, check if the button "Reactivate current plan" still there, click on it if so,
then logoff my account and reboot your phone and you should be all good
