Okanagan Outages? 11.03.22?
03-11-2022 12:05 PM
Anyone else in the Okanagan Lake Country specifically that doesn't have cell service? Thanks
Service
03-11-2022 09:21 PM - edited 03-11-2022 09:23 PM
@HeddleTown wrote:Anyone else in the Okanagan Lake Country specifically that doesn't have cell service? Thanks
@HeddleTown - if there are no outages reported in your area try some troubleshooting below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
*manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls
ediit: perhaps you could share if this is a new or existing account?
if just newly activated and still no services after suggestions given ask customer support (CSA) for assistance: two ways to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
03-11-2022 12:09 PM
@HeddleTown There is no outage according to Telus status page:
https://www.telus.com/en/nu/outages
So, you didn't see any signal at all? Did you login to My Account and confirm if your account status is Active?
do you have a 2nd phone to put the PM SIM in and see if it connects?
any friends in your area on Telus or Koodo ? Check with them if so
03-11-2022 12:08 PM - edited 03-11-2022 12:12 PM
You can check on the Telus outage map:
https://www.telus.com/en/yt/outages
But it doesn’t show any outages in your area.
