02-14-2022 01:27 PM
Good Afternoon, hope all is well.😊 I would like to top up my account. Can you kindly assist me? ❤
02-15-2022 03:02 PM
HI @Marlene77 In your case, you can try to pay by *611 if you know your 4 digits PIN.
If you don't have the PIN, you will first get access back to your Self-Serve My Account , then make the payment there to reactivate the plan.
To open a ticket with PM CS Agent for resetting the login, Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
02-15-2022 03:00 PM
are you over 90 days of non-payment, your account will be permanently deactivated,
02-15-2022 02:58 PM
I tried all of your suggestions and still unable to log in, when I call the number it says Not in service. Thank you
02-15-2022 02:58 PM
02-15-2022 02:56 PM - edited 02-15-2022 02:57 PM
if you cannot login to My Account, first try to use Forgot Pasword (https://selfserve.publicmobile.ca/forgot-password/), enter the correct email address aad then answer the security question. I
If you cannot reset it that way, open a ticket with PM Support and they will help resetting for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Forgot Login Information ", click "Contact Us", click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
Once you are back onto My Account, you can try what I suggested above for payment
02-15-2022 02:53 PM
Good afternoon VIP_Tech, thank you for your response. I am unable to log into my online account. I get the following message when try to log in or change password (
02-15-2022 12:26 AM
@BKNS27 wrote:Remember it is a 2 part step.
Pick the add-ons amount, pick the payment then submit.
In this situation, the customer isn't try to purchase an add-on but is rather trying to reactivate a suspended account.
02-14-2022 02:23 PM
02-14-2022 01:33 PM - edited 02-14-2022 01:34 PM
@Marlene77 you can still login to My Account?
and the account status is showing Suspended?
Please to go the Payment Tab, One Time payment (https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/)
then select "Other (Enter the desired payment amount)" and manually enter your plan amount
once payment gone through, click "Reactivate current plan" if the button is there
then logoff from My Account and reboot the phone
02-14-2022 01:32 PM
02-14-2022 01:29 PM
Hi @Marlene77
close all Browser and clear cache and cookies,
and try open one Browser inPrivate mode, or incognito mode,
Log In to Self-Serve,
Click on Payment
Make a Payment
Payment Type: select ( Amount Due )
Click ‘Submit’,
after payment successful, Reboot device.
