Re: resend transfer request
AMDASK
I have the same issue and need the transfer request again. Could I please have the contact support number as well?
HI @AMDASK
the number I sent you would work.  Please call, they close at 10, please call now
(it is a Koodo call centre, but Koodo and PM both owned by Telus, so the number I sent would work)
AMDASK
I am transferring from Freedom to Public. My authorization text timed out so I need Public to resend the request (I contacted Freedom and they said Public would have to request it again). Would the number from Koodo still work in this case?
HI @AMDASK
 PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
