7 hours ago
*61*1(your area code)5814001*30# doesn't work.
3 hours ago
Well, that's the end of that then. Thanks for your help. 😁
3 hours ago
sorry @Teecom , iPhone 6S is not on PM's VoLTE whitelist. So, the number of rings setup won't work.
3 hours ago
The phone is a iPhone 6s with the latest IOS 15.8.3 and voice and data is set to LTE on.
I don't know how to reach a support agent.
4 hours ago
hi @Teecom
what phone is yours? only phones that are on VoLTE whitelist can use conditional forwarding
if yours is one. Even it does not work, you can try to ask support agent to fix the conditional forwarding first. If that is fixed, you can try the # of rings
4 hours ago
I tried a bunch of stuff a few people suggested and nothing worked so I guess that's that. Thanks for your help.
4 hours ago - last edited 4 hours ago
@Teecom wrote:*61*1(your area code)5814001*30# doesn't work.
The voicemail deposit number isn't always your area code plus that number. There are many area codes that do not have a voicemail deposit number. As for changing the number rings, this might no longer be possible because of a change in the functionality of conditional call forwarding at Public Mobile.
6 hours ago
I have a iPhone 6s. I tried *61*16475804001*11*30# and get the error,
7 hours ago
