Re: iPhone Update and APN settings
sunvan123
Can’t get my mom and dads iPhone data to work after I transferred them from Telus.
tried to change the apn setting to : sp.mb.com
it still doesn’t work.
please help me.
Ferlea
This is all I needed to do for iphone4
"Connect your phone to wifi then using Safari visit http://www.unlockit.co.nz and follow the instructions on the screen. You should see this picture. Click "Create APN" and install it."
Ferlea
Hi!
This was complicated for me but I figured it out once Luddite posted this:
""Connect your phone to wifi then using Safari visit http://www.unlockit.co.nz and follow the instructions on the screen. You should see this picture. Click "Create APN" and install it."
So I have an iphone 4 and this info immediately helped me. I have an APN app on my iphone now. This is a essentially jailbreaking I guess. The app makes your phone do something it was designed not to, which is really cool.
If you have a new model than iphone4, I don't think this is necessary and Luddite can help with that!
Rockdaddy22
Any updates here?
Mana
@sunvan123 sorry to hear about your trouble.
If you haven't already please try:
- turn off the phone
- remove sim card
- reinsert SIM card
- power back up
Lg85
@sunvan123 Have a look at the link below for the APN settings for iPhone. You need to change a few more things in addition to the APN.
https://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update-and-APN-settings/m-p/1610...
Luddite
@sunvan123 You have posted to an old thread. In future you will have more assurance of help by creating your own topic on the forum  (which I have done for you today), or sending a private message directly to the moderators.
What model does he have?
Have you tried:
a) reset network settings (reenter wifi passwords) afterwards
b) check for carrier update: Settings >> General >> About: if one is offered install it
c) delete any VPNs
d) toggle airplane mode off/on
c) confirm cellular data and roaming are ON
d) login to his account to be sure data is included in his plan.
Do all other services work properly?
