06-14-2021 11:39 AM - edited 01-06-2022 02:52 AM
06-14-2021 08:52 PM
06-14-2021 08:35 PM
06-14-2021 08:27 PM
we're getting volte!
06-14-2021 01:43 PM
That all depends on the nature of the problem and how to fix it but given that its affecting several customers that we know about and telus is involved that you can be assured its being given a high priority. I imagine that this an technology/infastructure problem vs a system/account issue but either way I am sure they are scrambling to find its source and/or rectify it as quickly as possible.
06-14-2021 01:21 PM
OK
How long will it take with TECH team
06-14-2021 01:18 PM
Ask for the tech team ticket reference # so when you ask for an update you won't have to explain the whole issue to a new moderator. They will be able to easily just check the ticket # for progress.
06-14-2021 01:09 PM
@dkai12 you can reply the message and ask Mod to provide you an update.
Yes, Wed is around the day we saw people posting about the issue.
06-14-2021 12:50 PM
escalated to TECH team,
06-14-2021 12:49 PM
they are escalating it to TECH team.
but issue been on going since WED
06-14-2021 12:39 PM
says I'm on KOODO network
06-14-2021 12:39 PM
I tried all.
06-14-2021 12:31 PM
3G should be able to send MMS as well.
Have you open a ticket with Mod yet? I think you should , tell them your situation, only 3G works for voice and LTE for text/MMS and see what they say.
06-14-2021 12:28 PM
@dkai12 , can you confirm your data is set to on? Although it doesn't consume your data, it needs to be on for MMS.
Also, just for a test, you can try to change it back to LTE and see if the MMS goes through
06-14-2021 12:23 PM
Yes turn to LTE I can send text messages pics but NO incoming call again!
06-14-2021 12:19 PM
MMS should still work on the 3G network.
06-14-2021 11:46 AM
@dkai12 SMS and MMS would work on 3G too. Can you confirm if your Data in turned on?
also, just a test, did you try to change it back to LTE and see if you are able to send and receive SMS and MMS?
06-14-2021 11:31 AM
Yes
But can't sent Text Messages with Pictures now.
06-14-2021 10:49 AM
06-14-2021 10:49 AM
@dkai12 you have changed to 3G Only? but are you going incoming calls?
06-14-2021 10:39 AM
Still not connected to LTE
network
also my text pics are not working on 3 G
unacceptable
06-12-2021 02:57 PM
don't know what happening, but it has been couple days for sure.. i have a feeling it's not just Ottawa.
06-12-2021 02:45 PM
@Anonymous
I have no issues with calling in Vancouver. Both my phones rang when I called them.
06-12-2021 02:39 PM
Yes out calls work
thanks
