Re: [Update] More is Merrier is back!
rossputin
Is there a way to stop recieving notification on this topic?  It seems I didn't subscribe but I did post a couple of times.
9 REPLIES 9
Hi @rossputin  , did you check the subscription list:
https://productioncommunity.publicmobile.ca/t5/user/myprofilepage/tab/user-subscriptions  ?
it could be a long list, couple pages, but likely it is there.
Once you found the thread there, you need to check the box on the left and then do this:
Also, you might be "fallen" into this thread subscription because you replied another post earlier, another thread title but our good Oracle merged it into More is Merrier and hence you becomes a victim now 🙂
I think instead of spending time finding it, disable email notification till at least Jan 2, then hopefully no more reply here.
rossputin
@Anonymous Ha.  "Automatically subscribe me to all topics or reviews I participate in" is checked.  Good call.
However you'd think unsubscribing would be an option.
 @rossputin : Then the only other place I can find so far is maybe you have some of these options on. Like bravos.
rossputin
@Anonymous I'm a fray🪢
 @rossputin : And what about the one up top next to the top Reply button...the 3 dots.
rossputin
Thanks @hTideGnow
But that's the thing.  I'm not subscribed to it. It does however offer than I subscribe to it?😂
But while I have you et al, what is the appropriate forum for non PM topics?  Looking to buy a (minimal) tablet .
Hi @rossputin  you can unsubscribe this particular thread by  clicking on  your Avatar on the top right , click My Subscription and look for this thread on the list, check the box and  unsubscribe.
Or or temporary , just disable email notification.
Or, just wait .  Since Jan is coming , this thread will die down soon 🙂
 @rossputin : 3 dots up at the top of the thread next to Reply. Unsubscribe.
Triguy
@rossputin You probably had a check mark in the box when someone replies email me.  It is checked by default and you need to remove it before posting it else you get notified.
