I phone 13
akoeto1207
Does i phone 13 works with public mobile
HALIMACS
@akoeto1207
You'll likely find that virtually ALL devices sold within the North American market FOR USE WITHIN the North American market will work with Public Mobile.
Where users run into troubles is when they purchase a device from an international destination (Eastern Hemisphere) designed for destinations in the far East.
Also, it's important that devices are not locked to a previous carrier nor are blacklisted for use.  One can check that here:  Check the Status of Your Device in Canada | DeviceCheck.ca
@akoeto1207
Yes is will working with Public Mobile.
visit Here link to you review full information,
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
visit  Here link, to check it all Provider in Canada about compatibility with any device..
Triguy
Yes, it is compatible with PM.
Dunkman
Yes.
