Re: Mexico plan
YYCCalvin
I’m have the same problem and on a LTE network. I received a few calls but can’t place a call?
wife is having the same issues
2 REPLIES 2
C8ering
Try add the + to your numbers.
+1-xxx-xxx-xxxx
it worked for me when calling Canada from Mexico
hi @YYCCalvin
in US or Mexico?
you data works?
what phone do you have
did you try different network?  If you are in US, try manually connect to T-Mobile, AT&T, Verizon
if you are in Mexico, try manually connect to AT&T or Telcel
