02-09-2021 11:01 AM - edited 01-06-2022 02:04 AM
02-09-2021 04:23 PM
It sounds like you have used up all your plan data but have not recieved your 5gb data bonus from your recent activation. Although the promo states it will be added within 30 days it has been added earlier than that for most. Contact the moderators and explain your situation and ask them if they can add the 5gb to your account now.
02-09-2021 04:05 PM
hopefully you didnt run out of your data. Please check this either in your phone setting under mobile data used or on your PM account under usage. If it is not all used up then we will go from there.
02-09-2021 11:08 AM
@shaymckay wrote:I need my data and it wont let me use my data. HELP
Check your self-serve, have you consumed your allotment for the current cycle? If so, there'll be no data amounts shown under Data and Add Ons.
Solution?: Find Wi-fi, purchase data add-on, change plan to one with higher data component (could be costly depending on how close you are to next renewal)
02-09-2021 11:07 AM
Log into your account. Does any amount appear ? Have you setup APN settings ?
02-09-2021 11:06 AM - edited 02-09-2021 11:07 AM
Log in to your account to see if you actually have any data to use. Look in My Data and Add-ons to see what's in your current plan.If you see no data, then you've used it up.
