06-11-2021 12:08 PM - edited 01-06-2022 02:51 AM
06-13-2021 12:19 AM
Yes for the OP for their situation atm. Whatever problem the network is having that telus is trying to fix is having enough of a delay that its causing calls to default to voicemail. Thus by staying in 3g there is no delay and the call rings thru to the users device.
06-12-2021 10:41 PM
@thompsonpaul PM is not anomaly.. All three Tier3 providers are like this. This is to provide cheaper plans but at the same time make them less competative to their Tier 2 cousins, try not to overlap the market
06-12-2021 09:45 PM
@thompsonpaul : PM can do data and text on LTE/4G but talk only on UMTS/WCDMA/HSPA/3G. It can also do data and text on those.
If the phone is set to LTE first then it idles there. When a call comes (or made) the phone switches to 3G. Then back to LTE.
Setting it to 3G first let's the phone stay in native 3G all the time. Data may be faster but there's some latency.
06-12-2021 09:34 PM
Is your suggestion to specify settings to only connect to the 3G network, @darlicious ?
Public's a bit of an anomaly in that they actually use the LTE network, but limit the speed to the equivalent of 3G. So I'd assume leaving the phone set to connect to LTE will actually provide better, more consistent signal quality with better latency etc. Even though receiving 3G speed.
06-12-2021 03:03 PM
06-12-2021 02:39 PM
@dkai12 Yes, try the 3G only.. if not, open ticket with mod first while we try to help
(I see you replying on 2 threads on the same issue, let's stick with this one, easier to manage)
06-12-2021 02:38 PM
Ok trying
06-12-2021 02:26 PM - edited 06-12-2021 02:37 PM
can you tell us what you have tried?
1. you try changing to 3G only?
2. are you in the Ottawa area? PM confirmed there is issue in the area.
3. have you open a ticket with mod yet? If not, please do so
(after open ticket with mod, please monitor the Community Inbox here)
a. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot , then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
b. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-12-2021 02:10 PM
Still going into voicemail
thanks
06-12-2021 11:55 AM
Do you live in the Ottawa area?
A few customers also have the similar issue.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Calls-not-receiving/td-p/694700
PM/Telus is working on the issue. One customer was able to get calling to work by manually selecting 3G network.
06-12-2021 10:28 AM
time to open a ticket with Mod if you have not done so:
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot , then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-12-2021 09:42 AM
Try all that
not working
06-12-2021 08:58 AM
@dkai12 wrote:how to change 3g
Do you have Android or iPhone?
Here is a link:
https://www.wikihow.com/Switch-from-4G-to-3G-on-Android
Is text and data working fine?
Maybe also try the following: (if you haven't tried)
network reset of phone
make sure "do not disturb" function is not set on.
toggle airplane mode on/then off.
Try your PM sim card in another working phone. Helps determine whether hardware setup issue versus PM service problem.
06-12-2021 06:19 AM
how to change 3g
06-11-2021 10:18 PM - edited 06-11-2021 10:19 PM
@dkai12 Try changing the network to 3G only for now. I see some good news that calls are working again after changing to 3G.
06-11-2021 10:02 PM
@dkai12 wrote:been trying with moderator since noon
not acceptable
did you check your Community inbox (envelope on the top right) Mod will communicate with you via messaging you there.
Worst case , message them directly for update
06-11-2021 10:00 PM
yes out calls working
just incoming calls
also says KOODO now as service network
06-11-2021 09:46 PM
not acceptable
06-11-2021 09:45 PM
I took sim out
still going into VM
Please help
06-11-2021 09:44 PM - edited 06-11-2021 09:45 PM
@dkai12 wrote:trying to solve case with moderator
no sucess
please help
If there is an issue with your specific account, you'll need to keep working with the moderators. Only a moderator can fix an account issue, if there is one.
Are outgoing calls working? I'm trying to determine if the wrong type of network is being connected to as connecting to the HSPA+ network is required for voice service.
06-11-2021 09:32 PM
no sucess
please help
06-11-2021 09:30 PM
existing line.
just happened 2 days ago
all calls going into voicemail
I try to reseat sim and same issue
please help
06-11-2021 07:31 PM
Oh right...I didn't notice the change in customer.....
06-11-2021 06:40 PM
@dkai12 you have registered on Community for some time, is this issue for an existing line you have ? or a new activation?
if new activation, follow the instructions above.
If it is for an existing line, did you try reseating your SIM yet ? Power down the phone, take the SIM out, wipe it clean, put it back and power on.
06-11-2021 06:29 PM
Do you still have your old sim card? Put it back in your phone. You will still have full service with your previous provider. Then either contact the moderators as instructed or you can call the telus porting department with your old account # and request to port your phone number back again.
With the old sim card in the phone make sure you reply YES to the porting authorization text within 90 minutes of recieving it. (You probably missed this step the first time.) Once the service stops on the old sim card you can put the pm sim card in your phone and reboot. All your services should be working on your pm sim card now.
I will send you the porting dept. # in your private message box. The envelope icon at the top right corner of your screen next to your avatar.
06-11-2021 06:10 PM - edited 06-12-2021 03:12 PM
When Are Moderators Available And How Long Till I Get A Response?
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Moderators are available:
you submit a ticket to the Moderator Team !
for more information visit HERE
just be patient with Moderator Team the will help you 100%
just be relaxed
Good Luck
06-11-2021 03:43 PM
please help
all my calls going to voicemail
06-11-2021 02:56 PM - edited 06-12-2021 03:13 PM
can you do try reseat the SIM card
1.power off your device
2.take out the SIM card,
3.wipe it clean,
4.put it back and power on,
5.toggling airplane mode off/on,
it happened sometime you know, A normal reboot without reset, didn't work. At least try it,
only work after reseating the SIM card.
can you try it selecting the network to "3G ONLY"
for iPhone visit HERE
or HERE
for android visit HERE ,
what is mean for Rebooting the phone means to turn off your phone and turn it back on.
if is still have same issue you have to Submit a ticket to customer service by Moderator Team,
Here’s how to contact customer service by Moderator Team,
Good Luck
06-11-2021 02:40 PM
pls help
06-11-2021 02:40 PM - edited 06-11-2021 02:46 PM
Good Luck
