09-03-2023 01:02 PM
I used up all my data on my existing plan and still have 2 more months till renewal…. If I switch, what will happen?
09-07-2023 10:21 PM
HI @Toxin
Yes, you can . Just login My Account and go back to Change Subscription, you will see the new plan showing as scheduled change, just click Cancel Subscription Change and all good
09-07-2023 10:20 PM - edited 09-07-2023 10:21 PM
@Toxin Yes in subscription add on page , you will see your current plan and up coming plan and option to cancel like this
Cancel plan change
09-07-2023 10:13 PM
Once I select a plan to be changed upon renewal, can I still change my mind and not change or change into another plan prior to renewal date?
09-07-2023 12:03 AM
Public mobile does not pro-rate plans. If you change plans earlier, then you will lose whatever is remaining in the original plan. Also, it is unknown if Public mobile will keep a Canada-USA talk, data plan in the future. If you are on a promo plan and switch out, it might not be available to switch back.
09-06-2023 11:14 PM
I would just leave networks on automatic and if already on 5G I would leave it on 4G and leave roaming data on.
09-06-2023
11:11 PM
09-07-2023
12:20 AM
Dunkman
Are there things I need to watch out for if I change plans every cycle? I was thinking of switching plans to reflect where my location (US or Canada) is going to be during each cycle.
09-03-2023 01:04 PM
@Toxin In the event you just want to change plans immediately you will have to pay the full price of new plan upfront and start a new 30 day or 90 day plan depending what plan you want to change to . You will keep old rewards and have them for your following renewal
