09-11-2022 08:02 PM
I also had the same problem. When I followed your instructions, I found "Change SIM Card" option under "Quick Links" is disabled, meaning I am not able to click Change SIM link. Please advise. Thanks.
09-11-2022 11:41 PM
Common answer to all the posts.
09-11-2022 10:21 PM
@Alexandf wrote:open ticket with PM support and ask them to change it for you
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
There's no reason to contact a CSA to change the SIM card.
09-11-2022 08:36 PM
@bramptonian Yeah, unfortunately, it seems PM has disabled that option recently and I only became aware of it myself couple of days ago, but as suggested clicking the Profile from the left hand side of login page will give you the option to Change SIM and other functions.
I'll update the information in my earlier post to reflect this.
09-11-2022 08:18 PM
09-11-2022 08:10 PM
@bramptonian try from the profile page instead. Click Edit Account information and there is a section about Change Sim card there..
