08-30-2026 09:29 PM
I recently ported back from Fizz. Data and ongoing call works but INCOMING calls disconnect immediately. Please help.
08-30-2026 09:52 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please open ticket using Public Mobile Expert Messaging , Select Start a Chat to begin (You will need to use your current Community account to login to submit the ticket):
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/sms alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
