Re: Android 8.1 APN settings
dawoodsubedar
I have the same problem with UMIDIGI Z2. It seems that this is a problem on any Andoid 8.1 phone because the APN settings are not editable and the carrier is providing only the  sp.telus.com  APN which is an incorrect one for Public Mobile.
1 REPLY 1
killer23d
This issue is due to the poorly built rom using outdated apns-conf.xml which defaults to Telus APN when it detects the Telus MCC on the SIM.
Since PM is a Telus MVNO so the only way is to add a new APN which is can be found here: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
If it cannot be added on Android then you are SOL without root, with root you can use the updated xml that reflects the changes.
