05-06-2026 03:04 PM
Had my phone and been with public mobile for 3+ years, have a Samsung s21 fe.
The past few days my signal has been cutting out for long periods of time.
Sometimes it will say I have 5 bars, but there's no 4g or 5g next to it and have no text or Internet capability.
Can connect to wifi no problem, but sometimes I can't text or send pics to certain numbers without that cell signal.
I haven't changed location, I'm not under a tin roof although that's what it seems like, I'm in Edmonton, on the 100gig, 5g plan.
I've tried setting to airplane mode then off, resetting my phone, walking 100m away and nothing.
05-08-2026 03:40 PM
@jackass87 wrote:This has been going on with me since bell announced they wanted government funding for dead areas. When the bell/government grant/scam is complete, this shouldn't happen anymore.
HI @jackass87 what area is that?
05-08-2026 03:39 PM
hi @BenG888
new sim won't fix it, you just need to check with PM support and they can refresh the account for you on the system.
I suggested you to open ticket earlier, have you opened one yet?
05-08-2026 03:34 PM
Wondering if anyone thinks that if I buy a new SIM should it fix this problem? I won't have to change my number would I? Just swap it out and swap my plan over?
05-06-2026 06:28 PM
05-06-2026 03:41 PM
I have a nano sim
05-06-2026 03:39 PM
No I'm in Edmonton
05-06-2026 03:09 PM
What kind of SIM do you have?
If it is physical SIM then it could be issue with connection with SIM. Clean post, clean contacts...
05-06-2026 03:09 PM
hi @BenG888
are you in Vancouver area?
there is wireless degradation in the Vancouver area since April 11, still an issue at the moment. Not sure if you are affected
https://telus.com/en/bc/outages
or try Reboot phone and Reset network settings
if same, ask PM agent to check. submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
