09-30-2023 07:44 PM - last edited on 10-01-2023 01:10 AM by computergeek541
09-30-2023 09:00 PM
Hey @Shariff
Are you porting TO Public Mobile or TO Freedumb? The way it looks is you're porting TO Public Mobile.
09-30-2023 08:15 PM
Maybe @Chalupa_Batman
“Freedumb” — nice 😂
09-30-2023 07:53 PM
I read it as he's porting to PM from Freedumb.
09-30-2023 07:49 PM - edited 09-30-2023 07:50 PM
Porting away from Public Mobile is all on the new provider.
Just make sure you keep your Public Mobile SIM card in your device to reply “yes” to the port authorization request.
09-30-2023 07:46 PM
Hi there @Shariff
Check your mailbox in the top right. I will send you the number to call them.
