RE: Visiting France
09-25-2019 04:45 PM - edited 01-05-2022 07:16 AM
09-25-2019 06:58 PM - edited 09-25-2019 07:02 PM
Also look at VoIP.ms and use an app called Zoiper. Check out what phone numbers that VoIP.ms will give you. Use with wifi or a cheap data plan as mentioned.
Also do have heard most European plans have free incoming calls? Check them out before you leave. Also have seem SIMs sold in airports.
09-25-2019 06:40 PM
Primary carriers in France are Free, SFR, Bouygues Telecom, and Orange. I'll offer some advice on the carriers there instead since everyone already suggested to use VoIP apps and wifi.
I have no experience with any of them, aside from service and coverage (I was travelling in both UK and FR and EU roaming is free so I just used O2-UK because that's where I landed first), but I heard that Free is probably the cheapest (no experience at all as roaming on Free was the only network that wasn't permitted by O2) that you can find.
Coverage is decent, all of them are alright, but if I had to choose the better one on coverage, would be Bouygues. There's also coverage in RATP (subway), but some stations will result "No Service" or Edge (2G) coverage only.
Plans start at 2 Euros (Free is the cheapest but comes with almost no data). I saw Bouygues has a visitor's plan for €39.90, but is quite expensive so just find some suitable prepaid SIM. They might have MVNOs, not sure about them as I just visited for three days...
09-25-2019 04:57 PM
I heard france had ridiculously cheap plans, 15g of data with unlimited North America for 15 euros. Talk to family or friends who went there or go to forums where you can get advice.
just install fongo so people from canada can reach you.
You can move to 10 plan while away, or let your plan expire up to90 days, don't forget to login and renew before you lose your acount
09-25-2019 04:54 PM
@Mountainmaxman You may need to get an internaltional SIM card. Check out AOW if it meets your need.
09-25-2019 04:52 PM
You can also use the VoIP apps on data, of course, if you get a prepaid SIM card in France. I'd suggest Fongo for VoIP apps, as well, which gives you an actual Canadian number that your friends/family can call while you're away.
09-25-2019 04:48 PM - edited 09-25-2019 05:48 PM
@Mountainmaxman wrote:I am going to France next month and wondered if our phones will work there. I don't see any roaming add ons other then USA. Please help
@Mountainmaxman Unfortunately your phone will not work there. Best to purchase a local prepaid sim card. If you have Google Hangouts Dialer you can use it with Wi-Fi to make calls to anywhere in NA for free.
09-25-2019 04:47 PM - edited 09-25-2019 04:48 PM
No roaming options for France or any other country besides USA. Suggest getting a local sim card.
Look into free voip apps like maybe TextNow.
Safe travels.
