RE: CHANGE SIM CARD ASAP
jimbrosburrito
HI I NEED TO CHANGE MY SIM CARD MY PLAN IS 55.00 MONTHLY
7 REPLIES 7
DDM69
I think more details are needed here.  Why do you want to change your sim card?  Are you trying to change your plan?  Does the card not work?  Please explain fully so you can get proper assistance.
@jimbrosburrito wrote:
it wont allow me
@jimbrosburrito
What error message you got?
Try again using Incognito mode and see if it works
Again, you need to login to My Account, click Change sim card from the Quick Links menu on to top right and complete the process there
@jimbrosburrito
Why do you need to change your SIM card? Is it broken? Have you tried in another unlocked phone?
@jimbrosburrito Just click on Change sim card button.  But you have to have a brand new sim card though.
jimbrosburrito
it wont allow me
Metal1967
@jimbrosburritoyou already have service? .. you can do it easily in your account
walker1
@jimbrosburrito   To change sim card, you can do that yourself from inside your account.
