02-17-2022 02:45 PM - edited 02-17-2022 02:48 PM
So not sure if I missed an announcement/update on this recently or perhaps more likely that it's always been worded this way, but was wondering if anyone can confirm whether PM made any changes to the RAF rewards with the rollout of the new Public Points. The wording for RAF rewards says it got a makeover and not sure what the makeover is unless the cap has been decreased?
Edit: on second read perhaps it's just that the rewards are now being called points instead of dollars...
02-17-2022 04:46 PM
@dabr wrote:So not sure if I missed an announcement/update on this recently or perhaps more likely that it's always been worded this way, but was wondering if anyone can confirm whether PM made any changes to the RAF rewards with the rollout of the new Public Points. The wording for RAF rewards says it got a makeover and not sure what the makeover is unless the cap has been decreased?
That is for people who have adopted the new point system. Old reward system is still $1 a referral.
02-17-2022 04:33 PM
@darlicious Lol...I didn't even think about the acronym 😁
02-17-2022 04:32 PM
02-17-2022 04:30 PM
Agreed and I was trying to figure out when the Royal Air Force started a points program and for what? Lol...
02-17-2022 04:28 PM
@softech @darlicious @HALIMACS I think I just got a little confused with the "makeover" reference and that there's really no difference between the old rewards and the Public Points that I can see other than that points need to be redeemed vs just getting added to account balance on the payment date. I do think the grandfathered in rewards are much less confusing though..
Oh well...
02-17-2022 04:14 PM
Still... those of us remaining in the old rewards will continue to get the $1 / new referral, correct?
I'm certain the answer is yes, but just double checking.
02-17-2022 03:40 PM
Pm has put themselves in a bit of a quagmire by having rewards marketing and promotion appear for customers on the points program. I imagine there is going to be a lot of messaging trying to get the message across but in its usual method pm trying to clarify one point only makes its other messaging all that murkier.
02-17-2022 03:07 PM - edited 02-17-2022 04:51 PM
@dabr The main difference is you early 1 point every month.
Assuming you have no other rewards (which you wont 🙂 ),
in the old system, PM will give you $1 and deduct that $1 in the next bill
In the new system, you get 1 point but you cannot use the 1 point right a way. You have to accumulate ( @Anonymous 😋) to 15 points first , then you use the 15 points to "BUY" the $15 bill credit, then, PM will apply the $15 to your My Account as Available Fund
So, old system, the $1 will be used immediately in the next payment
in the new system, the point cannot be used until you have 15 points. Even with 15 points, you have to go to My Rewards to request convert to bill credit (if you don't do that, the point will just keep going up in the Rewards system)
