02-12-2024 03:04 PM
Hi, I put down current subscription of $34 30G into $40 60G by ' change on renewal' , but I can't make it to be 90 day subscription options, and I also can't see how much it would be under 90 day subscription. Anyone can offer more details about it? Thank you.
02-12-2024 09:21 PM
I see that plan in my account.
02-12-2024 08:59 PM
@rachelwang wrote:but I didn't see it,there is only &60/60g offer a 90-days options based on the showin in my account.
As I was mentioning earlier, there is no such plan that gives 150GB over 90 days for $102.
02-12-2024 08:04 PM
02-12-2024 05:30 PM
02-12-2024 05:26 PM
so the 90-day option is not available for the $40/60G plan,isn't it?
02-12-2024 03:11 PM - edited 02-12-2024 03:12 PM
@rachelwang wrote:Hi, I put down current subscription of $34 30G into $40 60G by ' change on renewal' , but I can't make it to be 90 day subscription options, and I also can't see how much it would be under 90 day subscription. Anyone can offer more details about it? Thank you.
The 40GB/60GB plan is the wrong selection. You need to first select the $40/50GB plan. After doing that, there will be a 90-day option for $102/150GB. Currently, there is no $102/180GB plan.
