a week ago
I checked around but cannot find
what is the hotline number? have questions with joining
a week ago
yes, I have Android. I think I know what you meant. will try that or ask friend to help as backup plan. thanks
a week ago
You need to use the Canadian version of the App stores
a week ago
yes, going for hard sim , I have one from my friend. I might ask him to help with the app
a week ago
@jupsonilte do you have an iPhone or Android?
If you have an Android,.you can download PM app from some reliable APK site and sideload it and start the subscription that way
a week ago
hi @jupsonilte are you activating a physical sim?
if you are, you can ask a friend to install it and help you with the activation. After activation, you can do everything using the browser and you don't need the app again if you don't want to
a week ago
oh, no hotline. Then support could be hard
I cannot download the app, it complains about Region or Geo, what to do?
a week ago
hi @jupsonilte there is no number to call direct, everything done through Community with customers here , or you message support agent here
you can submit by direct message:
Or you want to share your question here?
