Question on account
Csrf071990
i changed my plan today as it didnt auto renew and now i cant connect to the provider and it was working this morning till i topped up my acc with the $50 plan for 8 gigs of data.... really wanna know how long it will take to get it working as i paid and now i cant figure out why it wont connect.... Pixel 2 non xl can provide photos of my account if needed thanks! ive dont everything such as remove sim reboot... ect THANKS!
    Cody
10 REPLIES 10
@Csrf071990 wrote:
Won't work with my card
How about buying a $5 voucher from recharge.com and seeing if that kicks it to go. Which is what the $1 and the lost/stolen feature are suppposed to do as bit of a workaround.
The small denomination may be a little more expensive than buying in a store but I'm not sure a store would sell that small an amount.
Csrf071990
@Csrf071990
As you wait for moderator, you could also try manualling loading $1 to your account to see whether that re-starts your plan.  Moderators can take  a couple of days to respond.
Csrf071990
so everything worked but i cant call out or recieve calls..... gonna need a mod to fix it
@Csrf071990 wrote:
i cant find the report stolen function
@Csrf071990
Log into self serve
Click plans & addons
Click Lost/Stolen phone
Csrf071990
Csrf071990
Ok I'll give that a shot. But normally they will fix the problem? Just sucks as I like my phone and I know it's not the phone
srlawren
@Csrf071990 please see here:  https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
Csrf071990
how do i do that? is says my account is active?
  • mount Due: $50.00
  • Payment Due Date (One-Time Payment): Jan 17, 2019
Sharing is caring!
From Nov 15 – Jan 1, 2019 refer your friend to Public Mobile and both you and your friend will receive a one-time $25 account credit! See the Community for more details.
Need help?
Visit our Comunity. By helping others, you could earn up to $20 off your plan every 30 days!
My PlanAccount Status: Active
  • My Rewards
    • Community Reward $0
  • To learn more about Rewards, visit our Community
  thats what it says
popping
    Cody
Is your account still active?
If yes, your account may not be provisioned correctly with the new feature of your $50 plan.  You may try the lost/stolen phone trick to re-provision your plan feature again.
