Query
02-25-2024 04:36 PM
The 5g package which is 34 dollars for 50gb. Can i be used in a 4g enabled phone or area where up to 4g is available?
Plans
02-25-2024 04:43 PM
@lone_enigma22 Yes. Just means that it will connect to 5G network if your device is compatible. If not, it will try to connect at next fastest speed, 4G, LTE, 3G, etc.
02-25-2024 04:42 PM
@lone_enigma22 - Make sure that your phone is VoLTE compatible if you are planning to go to the USA, but a 5G, 4G, & 3G phone will work. 3G is slower, but Long Range, 4G is good for most people & 5G runs off mostly from NSA 4G & 5G. https://www.publicmobile.ca/en/on/get-help/articles/volte
02-25-2024 04:39 PM
Yes the 5G plan will work on what your phone is capable so it will work on 3G, 4G/LTE or 5G.
