02-25-2024 04:43 PM
I made a mistake when I signed up. I thought I picked $29/month for 20GB. Instead I have $24 for 4GB. I got my Sim card and finished my activation today. That is when I noticed my mistake.
Being that I haven't used anything, can I pay the extra $5 and change.
I can't change through the vhange subscription menu because the promotions are not available.
Please help.
02-25-2024 04:46 PM
Once you activate on the plan you choose and want to change it. Just DM a CS_Agent to have it corrected.
02-25-2024 04:45 PM - edited 02-25-2024 04:48 PM
@KathyLois Try reaching out the CS Agent to see if they can switch the plan for you. Use this link, https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437.
Send them a note and watch your community inbox in the upper right hand corner. You should receive email as well if you have a new private message sent to you.
