Quebec and Ontario solicitations. 6 per day
Linkrat
How to stop them.  They always use different number
@Linkrat wrote:
Do you know how to block calls from an entire area code?  Or province?
hi @Linkrat
there are paid apps that can help, but you really want to pay for it?
My suggestion was to just don't answer the call if you don't recognize the callers number. Blocking an entire area code or province isn't possible...or advisable.
Linkrat
hairbag1
@Linkrat
if you don't recognize the calling number...don't answer the call. If it's a legit call, they can leave you a voice message and you can call 'em back if you want. After a week or so, those spam calls should diminish.   Once the bad guys know you'll answer any call, they'll keep hounding you.
@Linkrat
The numbers are spoofed to hide their true number. Try using the Truecaller app to minimize spam calls.
hi @Linkrat
unfortunately, everyone suffers from spam calls, too.  This is an issue for all carriers
PM does not have features like Call Screening.  So, you will have to  use device feature, like those Ring only if numbers on your contacts and send those others to Voicemail
