Purchasing an add on Plan
uni4ms
I have tried to add a US talk/text/Data plan, 15 days and it doesn't activate. I am in the US now.
10 REPLIES 10
@uni4ms - if this is the first Roaming addon you added to your account since in the USA, have you tried to restart your phone since you've added it?
Restarting, or toggling in/out airplane mode, even reset of network settings may help you connect to the proper network.
Is anything showing on your screen for networks available?
dust2dust
For me, the crux of the likelihood is, is this a re-buy of the same add-on?
If not then yes connect to T-Mobile only. Several of us have tried AT&T and it simply will not connect. No regulars here should be mentioning it.
And yes data and text should work fine as along as you're in a T-Mobile coverage area. Talk is the dodgy part. What make and model phone do you have? Some have removed the ability to drop down or even select 2G/GSM in the connection settings that is required for talk.
hairbag1
@uni4ms
depending on where you're going...the talk portion could be poor or non-existant even. Seems that the talk portion doesn't work in Alaska at all...not certain if others. I used it for trips to eastern Wa state and found talk works in larger cities but will diminish rapidly as you get away from towns. Make certain to manually select only T-Mobile...no others will work. You shouldn't have any negative issue using text or data.
If you plan on staying longer than 360 hours....don't rebuy the same add-on until 360 hours + 24hours has elapsed.
I agree with you that AT&T is somewhat YMMV.  However, I am unaware that it's been officially dropped.  Will confirm at next available opportunity.
@will13am   many of us has lost faith with roaming on AT&T.  Do you have a chance to check with PM using your channel to confirm if AT&T is still a roaming partner?
will13am
@uni4ms , there's no activation for roaming add-ons. It starts working once the add-on is successfully purchased.  Please confirm this using incognito mode when accessing your account.  Try manual connection to T-Mobile or AT&T if auto connection is not working.  Make sure that roaming data is turned on.
@uni4ms   first, which city and state you are at?
Getting data and text to work is not too hard, getting voice could be slightly harder
You might want to login to My Account using Incognito mode to confirm if the add-on was successfully purchased.  Check payment history, you should see PM too the money, make sure the money not staying in Available Fund but was actually used towards the roaming add-on
And do you see your phone connected to T-Mobile?  if not, on the Mobile selection page, manually connect to T-Mobile
And, make sure your Roaming Mobile Network is enabled on your phone
@uni4ms  First try connecting to T mobile and reboot device
edit
Check add-ons /mins /Data
LoveNature
Hi @uni4ms
close all browser and clear cache/ cookies/ open inPrivate mode,from computer. Login again,
check it in your add-ons, is showing in,
if your Purchasing first time add-ons, then for the other one you have to waiting for 24hr to repurchasing other one.
@uni4ms
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
