07-05-2025 04:59 PM
I purchased the us top up by mistake as I needed the Canadian one, is it possible to get a refund?
07-05-2025 05:10 PM
@DNAIsaac wrote:I purchased the us top up by mistake as I needed the Canadian one, is it possible to get a refund?
Hello @DNAIsaac
Customer Service Agents are very understanding when errors like this are made. As long as it's not used, you can contact them and I'm sure they'll gladly issue you a credit to your account so you may purchase the one you wanted.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
07-05-2025 05:04 PM - edited 07-05-2025 05:07 PM
ask Customer Support if they can make the change for you. Use the orange Chat bubble on lower right side of page to start that process.
added...use this link to message Customer Support if the orange bubble method fails...
