Purchased LD add one but still can't call LD
EvlPnut
I purchased a 400min LD add on before my old LD add on was fully used up. Old add on is up, new add on shows on my account under the add ons but I still can't make LD calls.
7 REPLIES 7
CS_Agent
Customer Support Agent
Hello Rockdaddy22,
Thank for your feedback. 🙂
Don't hesitate to contact us if any concern or questions.
Cheers
Abdoulaye
Rockdaddy22
First time I'm seeing this survey, I like it 🙂
CS_Agent
Hi EvlPnut,
You're welcome. 🙂
As the part of the Customer Service Experience, I am inviting you to fill the following survey:https://telus.eu.qualtrics.com/jfe/form/SV_6tzYQ56VOqX4teZ
Cheers
Abdoulaye
EvlPnut
Solved thanks
Rockdaddy22
Please update us when everything is solved if you don't mind.
CS_Agent
Hi EvlPnut,
Thank you for reaching out to us.
In order to assist you, please send to us a Private Message.
Cheers
Abdoulaye
will13am
Send a private message to the moderator team and have them look into it.  They can be reached via private message using this link.
