07-13-2021 08:26 PM - edited 01-06-2022 02:47 AM
Is it possible to know the battery cycle count before purchasing a phone from PM?
07-13-2021 11:19 PM
Ahh...thanks Kerri1. I'd forgotten about the 30 day return. I can discover the battery cycle count very quickly with the device in hand. Thanks for the heads-up!
07-13-2021 11:15 PM
Thanks you for your response and clarification. It seems to me though that a quick inspection of the batteries cycle count, and the posting of that number would provide a potential buyer (me) with another level of assurance and confidence in the phone under consideration. Just a thought.
07-13-2021 10:23 PM - edited 07-13-2021 11:39 PM
@Kerri1 wrote:Nope, it is not possible.
But you do have an option to return the phone if you see the batter below 70% under PMs 1 year warranty program
While there's certainly a threshhold for a battery to be replaced under warranty, no such thresshold exists to return the device for a refund within 30 days. The buyer can just have a change of mind.
07-13-2021 08:37 PM
07-13-2021 08:28 PM
I doubt it. Honestly, unless you buy it from a physical store, I don't think you can get this information from any puchase online
But you have 30 days to return the phone...
07-13-2021 08:27 PM - edited 07-13-2021 08:30 PM
@Koombassi wrote:Is it possible to know the battery cycle count before purchasing a phone from PM?
Nope...but you get a great warranty with the phones from PM.
edit...All phones are backed by a 1-year warranty.
Certified Pre-Owned phones are refurbished, high-quality phones that have gone through extensive inspection, then cleaned and re-packaged so you get only 100% functionality. All of our Public Certified Pre-Owned phones come with a 1-year Certified Pre-Owned warranty, backed by TELUS, so you can shop with confidence. Plus, if you’re not happy with the device you selected, return it within 30-days of purchase under our Money Back Guarantee.
