10-08-2023 06:07 PM
Hi need help with my public points. There is no redemtion option showing. I have 62+ points and wants to reedeem it but no option shows up just "No Activity" message showing up. Thank you
Rewards
10-08-2023 08:22 PM
To redeem just login to your account on your computer or app>rewards>go to rewards>catalogue>select your reward>redeem>confirm.
10-08-2023 06:27 PM
hi @Robloxkid
please try login again using Incognito/private/secret mode on your browser. There should be a Rewards Catalogur tab and there you choose the $15 vill credit to add to cart and check out
if still cannot find it, submit ticket with agent and they can help to redeem
10-08-2023 06:12 PM
any help to you ?....
https://www.publicmobile.ca/en/bc/get-help/articles/redeeming-public-points
