Public needs to set up a better way for people to access accounts when they have more than 1 phone
Loraine
Impossible to get necessary help
7 REPLIES 7
CountyDownIeUk
Come on folks....how about a lending hand.
@Loraine has not been here much.
@Loraine have you open the ticket yet? you check your Community inbox?
if you checked and no reply, I would open ticket again, at least private message them again
Loraine
Been trying for over 24 hrs to get help
Yummy
What would you suggest?
Currently one account one email one customer. If you are handling multiple accounts I do not see a big deal to log off/log on.
Outdoorsman
@Loraine
@Loraine hello I disagree with you , it is very easy to get help either here in the community for most things or through a cs agent for account issues,the problem is learning to maneuvre through this online system it takes awhile to get used to, if you are having an issue with your account not setup properly
you need the help of a service rep if simon won't work for you use option 2
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
kaytus
@Loraine That is the way is it—one phone # per email account.
@Loraine   Public mobile My Account system is one account login (one email address) for one single phone line.  So, if you have multiple lines, you will need to have different email address to login
If you are unsure which email you used for your other lines, please open ticket with PM support as suggested on your other thread
https://productioncommunity.publicmobile.ca/t5/Get-Support/Need-help/m-p/902973/highlight/true#M6172...
