Public mobile
BRENDAG
  1. I signed up for public mobile, but have no service, any suggestions on how to fix this
9 REPLIES 9
@BRENDAG
If you have an account. Login to your account and see if it is Active. If it is Active,
check to see if there are any outages in your area:
https://istheservicedowncanada.com/status/telus/map
BRENDAG
I followed the steps on line, says I’m a member, have an account #, paid, put in the pm SIM card, phone says no service
darlicious
@BRENDAG
Can you go to your settings and change your network to 3G only. Then go to "About Phone" >>Sim card status>> signal strength>> What ___-dBm reading do you get?
BRENDAG
When I go to settings , says my provider is public mobile,
no message,
when I turn the phone on says no service, I don’t have service where I live, I traveled yesterday and still no service
HALIMACS
2.  Can you tell us what you have done to "sign up"?
3.  Without knowing this, we're just guessing...
BRENDAG
Cannot make or receive calls, I believe the sim is good, I have submitted a ticket, just taking forever
Yummy
Can you log in to your account and confirm it is active?
Can you try your SIM in another phone?
Do you get any message when inserting SIM?
@BRENDAG do you see the SIM connected to the network??  any error like SIM not provisioned or No SIm or No Network?  Can you make outgoing calls at all?
if you cannot even make outgoing calls or there is one the those errors, open ticket with PM:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
JK8
@BRENDAG
Are you a new customer? Did you try porting your number over? Is your phone unlocked? Try rebooting, resetting network settings or reinstalling SIM card.
